Amps
jknappen
Kentucky
Been out of the audio thing for a while. Want to put an amp on my speakers using the factory 5.0 ra2. I have changed out my factory speakers all around i have kicker kc135 in dash and Alpine spr-69 in the doors. Just need a little bit more power so i dont have to crank up the volume dial to hear it. May add some alpine tweeters down the road. What are the good amps these days for this purpose
Graygoose
Indecisive Car Owner
Oklahoma
Convert, for now.
small
There are plenty. What's your budget? I suggest going to local reputable dealers ,seeing what they have on the board you can listen too, look at the features, see what fits your space requirements and budget. See as many as you can, let your ears and budget decide.
But a good 4 channel will work, leaving the dash speakers powered off the radio.
jknappen
jknappen
Kentucky
Budget well i dont want a cheapo walmart brand type amp. And I do not need competition series top of the line. Why would i want my dash speakers left alone? Looking at going under either the back seat or somehow mounted behind the back seat on the back of the cab under the rear glass but most likely under the rear seat
baum
savage, mn
2015 Laramie
like he said go to stores around where you live and see what they have. amps have all different price ranges.
Graygoose
Oklahoma
Convert, for now.
small
Well I didn't mean front speakers left alone, just not amped as much as the doors. Use the power off the HU, but there are BIG 4 channel amps, and there are small full range class D, so measure what you can use.
autokraftgt
Hemi 6.1
Off the top of my head:
Alpine
JL Audio
Rockford Fosgate
ARC Audio
SKAR
Soundstream
Kenwood
Mosconi (higher end)
Kicker
Image Dynamics
Audison (higher end)
JBL
MTX
in no particular order..
jknappen
jknappen
Kentucky
Let me rephrase then. I want 1 amp to power all 6 speakers. Be 3 channels used 1 for dash and 1 each for the doors.
Are alpine amps still decent?
BlkRamRt
SoCal
HEMI 5.7
The pdx line is good. So you want 6ch amp?
Totalcomfort
Stay with a 4ch and power the dash speakers with the HU like was said above. I tried powering my dash speakers with the amp, but they would SCREAM at me when volume was turned up. Much better balance with just the HU pushing them.
autokraftgt
Hemi 6.1
For the record,
with amped speakers, if your gains are set correctly, you will have to continue to crank the volume to some degree to really start rockin...you have to increase voltage somehow and the volume knob does that.
adurm
FL
2015 RCSB
I agree with getting a good 4 channel amp and not amping the dash 3.5's. Going to be a whole lot cheaper than finding a 6 channel amp.
countrygunner
I tried to run my dash speakers , kicker 4" two ways, off the dash and the front and back doors off the amp. I have 6.5" up front and 6" x 9" in the back. Running the dash off the deck and the doors off the amp left me little to know control over the blending of the system with the deck I've got. Whic is a pioneer 4800 double din. When I switched them to the front channel of my kicker 4 channel amp I was able to control them better. Or should I say equally with the front stage. It was the opposite for me. You have to make sure your gains are right. At first I had them turned up too much and they screamed like you say. However I set the gains with a digital multi meter and got the voltages matched with what they should be. The sound leveled out and I was able to use the crossover on my deck to control the whole front stage together. It worked great. Plus you have the added benfit of your deck running cooler this way.
choquette
CUMmins 6.7
how do you plug an amp on the factory 5.0 ra2??
adurm
FL
2015 RCSB
Line out converter. Takes the speaker wires and makes them into a usable rca signal. Or have an amp that has speaker level inputs.
choquette
CUMmins 6.7
a dsp like ms-8 or jl soundsweeper etc...
scotts2012ram
Ms
I'd go alpine they've stayed true with there products. It's is from a guy only running a alpine hu
