ANC
leeroy300
BC Canada
2020 Laramie Sport
6.7 l
Is there a way to deactivate the ANC through the display. You are able to cancel this on a Nissan Maxima through a series of button pushing combo (can't remember the combo)?
leeroy300
leeroy300
BC Canada
2020 Laramie Sport
6.7 l
Ty but not that bypass l am wondering about actually being able to turn it off like l was able to on my 16 maxima. ln that place where l was able to turn it off l was also able to make adjustments tosuch things as park sensor parameters amongst many other things! All by pushing a combination of buttons/controls
Jerrybob
WA
The answer to your question is no. The harness will take the ANC out of the speaker system but you cannot do it through the display. Why do you want to?
JoeCo
NY
triggers migraine
I could see how that would be a problem. Musky Mikes solution might be your best fix. That's the only fix I recall seeing, migraines are awful and that's a really unfortunate side effect from your new truck!
leeroy300
leeroy300
BC Canada
2020 Laramie Sport
6.7 l
just wonder if that is all the jumper turns off ?
JoeCo
NY
@Musky Mike Any other side effects with the product or just eliminates the ANC?
No mention of it effecting anything else on their websites, reviews all look positive. However, always best to get the first hand knowledge from someone one here that is using the product.
leeroy300
leeroy300
BC Canada
2020 Laramie Sport
6.7 l
weird feeling in my head kinda like vertigo but only after long exposure like 2 hour drive AND yes turning it off made it better.
Jerrybob
WA
I was going to buy the harness because of a loud droning noise....apparently...lots of folks have same problem on 2019 trucks. I wrote to harness company....response was that only ANC is removed....nothing else is affected. I ended up not needing harness....drone noise was fixed with a couple of downloads at the dealer.....wasn't easy to get them to do it but once...applied....it worked. Good luck....migraines suck.
Musky Mike
NC
It doesn’t turn off the ANC. It dead ends the mic inputs, without the mic inputs the ANC doesn’t try to counter act the vibs/noise inside the truck. The harness is cheap and easy to do and you can remove if it doesn’t work. Some people have pulled the pins from the amplifier harness to achieve same thing, but it's easier to use the harness and just remove the harness if you want to go back to stock.
leeroy300
leeroy300
BC Canada
2020 Laramie Sport
6.7 l
I thought ANC also works on deading other sounds that are not just in the cab
Jerrybob
WA
That's correct.....no mics.....no sound bouncing around the cab. Everything else is unaffected.
runamuck
Air Force
dfw
6.7 dsl
that's what I did..unplug mics from the block under the driver seat. all else works fine
