Another Fuel Sending Unit
Ryno1500
California
Hemi 5.7 eTorque
I have a 2014 Ram 1500 and the fuel gauge started failing after I was rear-ended a couple of months ago. I had a brand new mopar unit installed and the dealer released everything. However, I am having the same issue still. Anyone have additional ideas?
Thanks!
Nick_rp
I=V/R
puyallup, wa
5.7 Sport
Check continuity on pins 2 and 3 to ground. Should be none. If there is, you may have a wire insulation break somewhere.
The "signal" the gauge receives is just a resistance value. If the insulation is broken it will throw off the resistance
Ryno1500
Ryno1500
California
Hemi 5.7 eTorque
Thanks. I think I might have to replace that harness. I played with it some and seems like everything is working, until I hit the right bump at least.
alphaprojects
