Another tire question
Donhoe
Ashtabula
I'm installing a 2/4 lower kit soon. I'm still running my stock 17" rims right now. New tires and rims are not in the cards till September. What tires can I run so it doesn't look silly, what will fit to fill up the wheel well? I have to pull off the fender flares and side steps to go from the look I want. Stock size is 275/70/17 or 65 /17/.
6speed4.7
Winnipeg
Just for fun
Here’s a picture of my ‘14 , 2/4 Belltech, with 17’s the day I traded it in at the dealership
It definitely looked unique
30.5” snow tires on the rims
Truck had 3.92’s, lightweight steel rims, 66lbs- had lots of performance compared to the heavier, taller tires
I know this is not what you want, but IMO it didn’t look awful...3F2E8BCF-8FA4-473A-AB53-C2D9C79D3954.jpeg
gbark80
Georgia
Here is mine on the stock 20s with 275/55-20 and cut coils on the bell tech kit so a lot closer to 3-5 now. If you go to https://tiresize.com/calculator/ and play around with different sizes, probably want to find something around 32 inches for diameter. Stock size on the 20s was 33 and I did get a little rub on hard bumps after I cut the coils down.
stevenmicheal
