Another Wheel Offset question - 3500
Big Eagle
Lone Butte, British Columbia, Canada
diesel
Hey all… yes another wheel offset question. I have a 2021 RAM 3500 Limited with the stock 20x8 rims and stock auto level suspension… no lift, no leveling kit. I’m running Toyo A/T III 305/55 now and they look and perform great. I went to buy aftermarket rims (Method 301’s) and they are an 18mm offset. When I looked at the stock rims, they are showing +54.65 offset (stamped on the mounting surface). If my calculations are correct, that means the new rims will stick the tire out 2” more than what I’m running stock. Is this correct? I really didn’t want to have my tires stick out much further and 2” seems a lot. Unfortunately I can’t find any aftermarket rims that are even close to stock offset. Any suggestions? Is 2” really going to look that different? Thanks in advance.
