anti-theft alarm
osprey ram
09 1500 4x4
4.7 lit.
I have 09 ram slt. Over the last year had alot of problems with key fob and alarm. Would like to disconnect horn associated with system. Is there a fuse for system ? All help appreciated.
Fast69Mopar
If you really want to disable the horns then you need to remove Fuse M37 and Fuse M43 from the TIPM under the hood.
Why not properly diagnose the issue so that you have a pair of working horns and key Fob's as well as the SKIM (Sentry Key Immobilizer) which keeps your truck from being stolen when someone shows up with a key that is not programmed to the WCM?
Just a thought.
On the other hand, tell us what type of problems you are experiencing and let see if we can provide some diagnostic support if you want too. There are plenty of real mechanics here with over 25 years of experience in the dealership like me and many more who have been in the independent shops just as well.
Here is a PDF of the wiring diagram for the horns..
  • 2009 Ram 1500 horn wiringdiagram.PDF
