Any advive needed and welcome
echo1911
Hey everyone. New to this forum. I have a 2002 dodge ram 1500. Recently my 4.7 has been acting up so I'm considering a swap since I'm going to have to spend some money anyways. Wanting to do this in the next 6 months. Any info is greatly appreciated. Not looking for a ton of HP but I'd like something I could improve on later. I did very little research on The 4.7 and there doesn't seem to be anything to really improve upon it. What would be the best options for a swap coming in somewhere between 6,500 and 9,500 dollar range. I would like to keep the stock transmission for the time being if possible. I've done replacement engines I'm the past but they were turnkey. Never really been Inside a motor. Probably don't want to do it for the first time on this particular project. Thanks in advance for any help.
GTyankee
El Cajon Calif. 92021
3.0 ecodiesel
what are you thinking about ?
Is your truck worth keeping, if it had a good engine ?
Pull the engine & see if it is rebuildable ?
Just buy a rebuilt engine & get your heads machined ?
OR WHAT
echo1911
echo1911
I'm wondering what motor other than the 4.7 would be the easiest to swap into my dodge. Doesn't necessarily have to be high performance for now. I would however like to be able to increase performance as time goes on with whatever motor I do swap into it. But for now I just want to know which motor I could later do work for more hp on. I want a larger/ better motor than the 4.7 though. And would like to stay with the current transmission uf possible. Not a bug deal of I can't though I reckon. Wanting info on options
Dean2
Near Edmonton
It is WAY easier to buy the more powerful truck. The 4.7 can't be built to be a real powerhouse and if you put something else in its place, tranny, electrical and a raft of other stuff needs to change. Far easier to just buy a truck with the bigger motor. The V10 in a 2500 and the 4.7 get pretty simialr gas mileage but far different performance. If you want to stick to a 1500, move up to the 5.7 Hemi. Just a whole bunch easier to get performance parts for.
echo1911
echo1911
I live this truck. Definitely want to keep it if I can. Thanks.
Ole Buck
South Alabama
If you are dead set on keeping it go follow my 4.7 rebuild, I did about a year ago on here. I have just about every upgrade that you can do to a 4.7 besides forced induction.
Oh yea there is a guy on you tube and his channel is martinbuilt. If it can be done to a 4.7 he covers it.
