Trey Sledge
Bought some after market head lights and the left side works perfect but the right side turn signal has issues. First one I had would work then not. Sent it back and now this one flick ere rs and then nothing. Any ideas?
Need more info. First off what did you buy? Second what kind of bulbs you running? Third are there any LEDs built in? Sounds to me like you just need to install resistors.
Where do you put the resistor, which wire?Oh yeah resistors will make it work. I’d put a resistor on both sides just to be safe in case something else decides to pop up on the drivers side later. When I got my recon tail lights my driver side kept giving me a bulb out warning and my passenger side worked fine put a resistor on both sides and no problems since.
I have a friend that can probably program LEDs in it for me. I was wondering about that.Crash seems to know more about the Alpharex lights than I do so I’d follow his word. The easiest way is to just get alphaobd and skip installing resistors.
^^^ thisThe easiest way is to just get alphaobd and skip installing resistors.
^^^ this
With AlfaOBD you can also set any of the lights LED and/or HID and you shouldn't have to use resistors.
I have the Modifystreet/Alpharex headlights similar to the ones pictured above. I used AlfaOBD to set the turn and running lights to LED. I also bought the wiring pigtails from M² Mods for dedicated DRLs. I enabled them with AlfaOBD and have them set to drop out w/turn signal.View attachment 180528
Yes it is a 2015 Outdoorsman EcoDiesel but the engine shouldn't make a difference(at least with nothing I've come across).Do you have a 2015 Ram by chance?
