- Joined
- May 27, 2023
- Posts
- 1,728
- Reaction score
- 1,907
- Location
- Sthrn AZ
- Ram Year
- 2023
- Engine
- 6.4 Hemi
You won't need that beast.I was thinking of a proPride.
I do, do primarily highway and towing/hauling. I have been looking at the Michelin Defender LTX M/S. I thought it only available in one rating based on the tire size?If you're doing primarily highway and towing/hauling, look at the Michelin Defender LTX M/S in an E rating. These are great tires that handle weight really well, are stable and no noise on the highway.
This says it better than I could.I'm not sure what you mean by rated for towing?
I run LT295/65R20's on my stock 20" black aluminum rims (equivalent to 35's).I do, do primarily highway and towing/hauling. I have been looking at the Michelin Defender LTX M/S. I thought it only available in one rating based on the tire size?
I had these on my 2018 and they were 115 load rating. Not sure if they come in a different rating or you would need a different tire, but 115 is plenty for your truck. They were great tires, towed great in the stock size.I do, do primarily highway and towing/hauling. I have been looking at the Michelin Defender LTX M/S. I thought it only available in one rating based on the tire size?
Out of curiosity I did a search on tirerack.com and confirmed my suspicions. Best load rating available on a 265/50-20 is XL and there are no LT tires in that size. They may exist somewhere but if tire rack doesn't have them then they would be rare if they exist. I would agree to go with a higher load range and an LT tire rather than what's essentially a car tire just to get a 50 profile.They should be at least Load Range "D" rated - "E" would be better if you're going to be towing a lot.
Plenty of LT’s out there in the OP’s factory size of 275/60-20. Tire Rack lists ten OE size LT tires in load range E.Out of curiosity I did a search on tirerack.com and confirmed my suspicions. Best load rating available on a 265/50-20 is XL and there are no LT tires in that size. They may exist somewhere but if tire rack doesn't have them then they would be rare if they exist. I would agree to go with a higher load range and an LT tire rather than what's essentially a car tire just to get a 50 profile.
I used 1/2" spacers and 6ply tires (275-60R20) I tow a camping trailer and have not had side to side as with the softer 4ply tires.Hello,
I have a 2020 1500 classic with stock 275/60-20 tires. When hooked up to my travel trailer, (WDB’s installed) if you push sideways on the hitch with your foot, you can see the tires roll from side to side. It was suggested I try 265/50-20 tires for better sway stability while towing. This makes sense and I know, the speedometer will be out, it’ll be a little rougher ride and they will look smaller.
I was wondering if anyone out there has tried smaller profile tires and if so, what is your experience.
Thanks!
What size are your Transforce tires, and what does your B-pillar say your PSI is supposed to be for them?I pull a TT in the 10.5-11.0K range with my 2022 TRadesman 2500 CC 6.4L 3.73 gears, all stock (including the Firestone Transforce tires). Had all kinds of problems with the new Flagstaff TT (has Goodyear Endurance tires) behind me. Forums told me about the problems with the Ram's Transforce tires and I wanted to try Michelin Defender LTX M/S that were on my prior Tundra. After trying two quality WDH setups, multiple adustments, etc., I was worried about buyiing new tires right away (my truck was brand new) and finding that new tires did not solve problem, so I bit the bullet and bought the ProPride. I hated paying for it, but man did it ever make towing more relaxing. Now I don't dread the drive, I can actually enjoy the trip AMAP. Can't really speak to OP's 1500 experience since I have the 2500, but plan to try the Michelin's when these TFs are near toast (currently about 39K miles). Happy trailering!
Stock LT 275/70R18. B pillar label has Front 60, Rear 65. Ran PSI all the way from 70 to 80 and still had side to side motion that was exaggerated on the road towing. Typically run about 70 psi now based on tire inflation chart when towing.What size are your Transforce tires, and what does your B-pillar say your PSI is supposed to be for them?
I'll assume that the 275 are stock on your because of the Crew Cab. Mine are 245/70R17 E, and the B-pillar calls for 75 front and 80 rear all the way up to GAWR. Strangest thing I've seen.Stock LT 275/70R18. B pillar label has Front 60, Rear 65. Ran PSI all the way from 70 to 80 and still had side to side motion that was exaggerated on the road towing. Typically run about 70 psi now based on tire inflation chart when towing.
I have the 275/70R18E and mine calls for 60psi front and rear.I'll assume that the 275 are stock on your because of the Crew Cab. Mine are 245/70R17 E, and the B-pillar calls for 75 front and 80 rear all the way up to GAWR. Strangest thing I've seen.
