MGD81
EDIT - all working well, will post some night pics when I get chance
I also posted this in the AlfaODB thread, but figured some here might like to see the V2's on a chrome truck.
So I went for it today.
I ordered the V2 lights, 2 x sets of Katana LED's for highs and lows and also the connectors from MPGrimm that allow me to use the factory DRL circuit - my truck is a Bighorn with quads.
Went mostly smoothly, with some finicky moments!
I'm stoked with the way the truck looks in person, I have everything wired right with as much factory look as possible. I used the DRL harness that came with the lights and cut the connector and mated it with MPgrimm's pins.
Everything works well apart from the DRL's - I have done the following
CBC features - LED front turn lamps present YES
CBC Features - LED front park marker lamps present - yes
CBC Features - LED low beam lamps present - yes
CBC Features - LED high beam lamps present - yes
CBC I/O right dedicated DRL Lamp output present- YES
CBC I/O left dedicated DRL Lamp output present- YES
CBC DRL config- OPTIONAL DRL
CBC features- DRL lamp location- DEDICATED
CBC features- DRL dropout enable- YES
CBC Features LED deicated DRL present- YES
ECU config- DRL customer setting enable/disable- YES
Daytime Running lights CSM- YES
Am I missing anything? I waited 5 mins to let the truck settle after the changes, do you think it needs a few more key cycles?
Matt
Matt
