Jbinramona
Has anyone heard if there is a flash update available to install Apple Car Play in my 2016 3500 Dually?
CorrectSo, without installing a new radio, CarPlay is not available in any 2016 model?
You can however swap to a newer factory radio to get carplay...well that sucks!
Thanks for the help guys. Now I know.
For the most part yes. You will also need the Hub harness which can be made by forum member @Mpgrimm2 . For a clean installation you may want to replace some trim pieces to install the hub. Your current setup (center console vs jump seat) dictates your options.So it sounds like the radio from a 2018 will give me carplay if I install the radio snd media hub. Is it a simple direct swap? If I can find a 2018 radio and hub in a junkyard will that work?
