muahahahahahah i secretly work for google!!!DAMNIT!
I clicked the link and now I have ads for this stuff popping up everywhere.
and that's all you'll ever need................
Same with wives..."with most additives, very hard to prove benefits over not using the product."
Not with wives..."But as with most things, if it gives peace of mind, then may be worth it."
Same with wives...
Not with wives...
I still believe it might help, but it's darn expensive. And so are...
It's just Borax in suspension with a bunch of esters and some paraffin. When properly suspended in a base oil Boric acid nano particles do work as a solid lubricant in high pressure areas.
https://www.tandfonline.com/doi/abs/10.1080/15567030802606053
Boron is often used in oils as a detergent and can be part of an AW chemical strategy so it's not much of a surprise to see it being used here, but damn the price is steep.
I could see how it would help with the sticktion issue on the Ford's as it is a cleaning agent, but IMO that issue is caused by maintenance deficiencies. Either the OCI is too long or the Oil choice was poor for the desired OCI. Once the issue is resolved it's then time to go to a more robust oil or more frequent changes... or both.
Any brand name motor oil needs to meet the API specifications in testing to use its seal. Motor oil improved a great deal in 2016 to work with the new engines. No need to add anything to what comes out of the jug.
With diesel engines a cetane booster helps the engine as does choosing a motor oil with a good additive mix (Amsoil by the way has one of the very worst).
