JMBaker76
2019 Ram 1500 Limited: My factory installed powerstep/running boards started making a loud noise when going down and up... and after down and up. Took it in to the dealer: it's covered under 3 yr 36,000 miles or for me, $1,200 because I have 39,000 miles. Are you SERIOUS?? 2 years old and the motor fails for factory-installed powerstep/running boards and I have to pay $1,200?? Is it just me... or wouldn't you expect a motor to last the 'lifetime' of the vehicle? NOT 2 YEARS??? C'mon Ram!! This is the **** that makes American Car manufacturers look bad. The motor for a powerstep/running board should not fail within the 1st 5 yesrs... MINIMUM. If it does, it is YOUR FAULT not the consumer. Step up and cover a failure in quality control. Don't shift it to the consumer. This is the 70's.
