HEMIMANN
- Dec 7, 2020
- 9,593
- 25,222
- Location
- Minneapolis, MN
- 2017 2500 Laramie Crew Cab
- 6.4L HEMI
That's common practice and a standard yes.
No, it's not. You've earned a block.
Hey Greg, did you need to raise the transmision a inch to clear the pan for removal?2014 dodge ram 1500 8 speed trany, change my fluid last summer 184000 km ,original fluid and it was black ,replaced the tranny pan with a dorman replacement that has removalable filter. It seemed to shift and run smoother, attached is the procedure i used, and a shot of the black fluid that was drained, drained 4/12 liters and added the same.
He hasn't been here in over a year,so you might not get an answerHey Greg, did you need to raise the transmision a inch to clear the pan for removal?
