backup camera installation info
welderboy6182
kansas city
I purchased a nos mopar backup camera kit for my 2011 bughorn off of ebay. it came with everything except the installation info. ive found a few pdf's of the original installation info off the internet but they are poor quality. I was hoping someone here has the original installation info from mopar? any help would be appreciated, thank you
W
welderboy6182
kansas city
yes,that's exactly what u need but the resolution isn't very good. was hoping someone had the original or a better copy of it
jawzs2
Air Force
South Jersey
try this, I knew I had it, just took me a while to find it
  • K6869459.pdf
jawzs2
Air Force
South Jersey
They should be able to, but I'd suggest doing it yourself with AlfaOBD, especially if you're planning to do other things to the truck. Probably less $ than the dealer would charge you.
If I remember correctly, it's only one setting you need to change, Rear Camera Present: Set
There is a very comprehensive thread all AlfaOBD can do in the 4th Gen DIY section. Disregard the comment it's only for 2013+, it works fine for stuff like this on the older ones as well.
