Bad wheel bearing already?
smurfs_of_war
Swift Current, Saskatchewan
15000km, get a scraping noise when turning right when the vehicle is cold, after I have been driving a bit the noise disappears. Checked for things bound up in the axles or brakes- nothing. No visible drag marks on the rotors either. I don't have any play in the wheels. The noise doesn't change when applying the brakes.
Just asking for opinions. Never had a wheel bearing be intermittent like this. Usually the noise is pretty constant.
Sent from my SGH-I337M using Tapatalk
Ramzaq
Northern California
2009 CC 4X4 3.55 Big Horn
Trying to remember, but there was a situation with the wheel well liner on the front that caused rubbing when turning. It was caused by a molded bump in the liner that accommodates a connector right behind it.
Don't remember which side but it is something you can look for.
Tach_tech
5.7L HEMI
Does it appear to be coming from the passenger side or driver side? Do you have the air suspension?
smurfs_of_war
smurfs_of_war
Drivers side. Turned out to be a hub assembly gone south. Replaced under warranty, good as new :)
