battery drain
Crusher23
Colorado
Im looking for help with what seems to be more and more common, battery drain issues. 2016 RAM 3500 Laramie Longhorn Limited. 6.7 diesel 60,000 miles. There are two batteries actually. The problem really started back in March. The truck wouldn't start but it only did it once so I figured it was a fluke. Basically it has been on an accelerated ramp to the point where it went back to the dealer. They called and said the brand new batteries that I put in 6 months ago are dead.
WTF?
I am not in the habit of throwing money around just because it is fun. I am not particularly electronically gifted so these other threads that suggest pulling fuses and setting up meters to measure current draw and the like might as well be in another language. Hopefully someone else from Colorado can point me in the direction of a reputable shop that can do this sort of thing.
Steve (Crusher23)
2003F350
6.7 CTD
What size batteries did you put in? If you didn't put batteries with high enough CCA then they won't last very long.
I haven't checked what size these are in my new '22, but I try to get a minimum of 850 CCA in my replacement batteries.
mtofell
Can't help with a shop recommendation but can tell you my truck does the same thing. I've been through a couple batteries and now just put it on a battery tender if it's going to sit for more than a week or so. I really don't know how long it's had the problem since the truck really never sat for more than a few days until about a year ago when I started splitting time between two residences. These newer vehicles are just to complicated electronically that these gremlins can be tough to chase down.
06 Dodge
6.7L CTD
For fun and giggles looked up what a few places listed to use, I was a bit surprised that several thought my 22 CTD only needed 730 CCA battery, others listed 750 CCA :favorites68:
tron67j
Maryland
Did you do anything, change anything, have any repairs done around the time the problem started? Not sure if the timing from your post, were new batteries put in about 6 months before the problem?
Assuming it was post-battery install it is possible that both were of a bad batch and caused the problem, and/or they aren't of sufficient amperage which could lead to the issue as stated above.
Since they are now replaced, hopefully with stronger batteries you should check with a volt meter before driving especially if left sitting for an extended time, and then after driving. If seems drawn down in the morning your going to have to start checking all connections, clean them up. If that doesn't fix, one way if not electronically savvy is to remove all fuses and then install one each night and check batteries each morning. When large draw happens, you might have found your bad circuit. Good luck.
2003F350
6.7 CTD
Surprising it only calls for 730, but 750 is usually the norm for a car battery period. I have yet to find a situation or vehicle where more wasn't better though.
Tron67j got me to thinking ..
There is an article that tells of things to look for & the reasons that you should look at them
We may all be doing some things incorrectly
truck2569
Clay Center Kansas
Electrical functions still work on the truck even when the key is off like the clock. I just purchased a Solar panel from Habor freight to remedy that problem.
mtofell
Yeah, and it's funny... I get answers all over the map to the question of how long a vehicle should be able to sit without starting. I know I've had some sit for as much as a month and fire up without issue whereas my Ram will die within a week or so. I'm pretty sure there's something wrong with mine but I just don't have the patience to try and fix it right now.
olyelr
Kewadin MI
WTF?
Steve (Crusher23)
Its not hard to test the batteries, if they did that and said they are bad, well then they are probably bad. It happens. When i bought my ‘16 power wagon (brand new) the battery died on me about a half year in. Dealer replaced. Then about 7 years later i replaced it with a heavy duty one from the parts store and that one died within the warranty period so they replaced it for free. Batteries can go bad early, it happens.
TC
Central TX
... I just purchased a Solar panel from Habor freight to remedy that problem.
Great idea. Are you connecting thru the 12 volt cigar lighter or hard wire to battery? Do you keep it connected at all times?
truck2569
Clay Center Kansas
Yes, I just go thru my cigarette lighter in the backseat my truck has a sunroof, so I put it up there and it stays connected all the time. I sometimes don't run my truck for weeks at a time so this was the perfect remedy.
