battery drain
draven
TEXAS
hemi 6.1
for a few weeks now i have been having issues keeping power to the truck. i have replaced the alternator with a brand new one, had to replace the connector to the alternator cause the old on was loose, changed the battery with a brand new one and replaced the cables with brand new ones and the it just keeps losing power, ill charge it over night and itll run a day or 2 but then im stuck with a dead truck somewhere on the side of the road, i constantly everyday with a alternator and battery checker and always have the same results thats its a good battery and good alternator. also my battery gauge keeps taking a dump on me, sometimes itll read good till i go down the highway and then it jumps to L and my check gauges light keeps coming on. im at my wits end on this and i need some help.
D
draven
TEXAS
hemi 6.1
i was told to run the truck aand disconnected the battery and the truck would still run and it did but after a couple minutes it stop and shut off and looked like the belt caught
im new to workin on cars in general so i dont have the knowledge
just asking for help
quacker
Wyoming
6.7L Cummins
I'm having the same issue on my 2013 Laramie Longhorn 6.7L Cummins diesel. I am an electrical guy, too. I was a turbine control systems tech at a power plant, so I understand something about the subject. One of the symptoms of a defective Body Control Module (BCM) can be a parasitic drain on the batteries, unusual idiot lights flashing on the instrument panel, door looks malfunctioning, electric windows malfunctioning, and accessories (such as courtesy lights) simply not working.
Woodsterr
Phoenix, AZ
Diesel
My 2019 Ram 2500 Lariot is having the same problem. After 4 sets of batteries I concluded it was the truck. The dealer discovered the BCM failing but 4 weeks later I'm dead again. The dealer now has it for the 4th time since I bought the truck. I believe if they haven't found the problem by now they won't find it. I'm preparing a Lemon Law action.
RamDiver
Marlborough, Ontario Canada
2021 DS
Are you here to announce your lemon law action or do you want to learn how to diagnose the source of a parasitic draw on the battery?
Arturo Rojas
