Battery issue?
Ternsdorff
Washington
Yeah, have had batteries take a dump in short time. Definately more chinesium ones out there now.
I just posed a question. Not going to get it 'diagnosed' by a 'qualified tech' unless I absolutely have to. Second, the few times I have involved a 'qualified tech' or dealer they've tried to screw me. So, again, no, not yet.
I also can't just go to the dealer as I have to work.
Getting the battery load tested is next, as it only takes some time.
2015 Ram 1500 SLT QC 5.7L 2WD, 147K miles
Battery replaced in 2019 @ 90K miles
Got a battery light this AM. No struggle or hesitation at crank. Drove to work 25 miles.
Checked with meter 12.7 V off, 14.4 running
Battery light still on, will recheck this afternoon.
No signs of corrosion, connections on/around battery all tight.
Thoughts?
Will take to O'Reilly's for load test tonight.
Ed buy yourself one of these cheap old school toaster style testers,they're still the best battery tester for doing just a battery load test in my opinion,and they're simplicity onto themselves to use.
Audiomaster66
Mid-Michigan
My friend just had this issue with the identical circumstances and it turned out it was a bad alternator.
2020PW
East coast
EdGs
EdGs
FL
Yes, going to get a tester for sure.
Incredible how sensitive the system can be to just a little shizzle at the connections.
All is good.....for now.
RamDiver
Marlborough, Ontario Canada
2021 DS
The first hint of a potentially compromised connection was that the battery voltage appeared reasonable when measured yet the starting was poor or problematic.
Sherman Bird
Houston, Texas
Might AGM architecture resist heat breakdown better? I know AGM does better in the cold up here - retains more CCA due to the higher surface area of the thinner lead plates.
My personal experience was with my 1989 D150 and my 1978 MGB. Both vehicles sat for extended lengths of time between uses, mainly because neither had A/C. Both ate lead acid batteries. The MGB was a real PITA to replace the battery inasmuch as it was located behind the passenger seat in a floor well. Unfortunately, I lost that car in the flood of Hurricane Harvey. Fortunately, it was insured as a classic through Hagerty. So was the D150. Hagerty was very prompt and generous with my settlement. The D 150 sat high enough that it sustained no harm.
But I digress.... both cars got AGM batteries and both cars were fixed.
HEMIMANN
Minneapolis, MN
2017 2500 Laramie Crew Cab
6.4L HEMI
U.S. military had the AGM developed for improved battlefield reliability. We consumers benefit for most of the same reasons. It's taken awhile for enough consumer demand to lower manufacturing costs. I recall one of early adopters were large boats with lots of electronics pounding through waves.
zogg
Southern Illinois
2018 Ram Express Quad Cab
My son-in-law bought a Walmart battery for his 2016 2 years ago. Crapped out last week. His oem went over 4 years. Ugh
RamDiver
2021 DS
Some people skimp on tires & batteries, I just can't relate to potentially compromising the safety or reliability of my vehicles, especially on a truck.
Maybe when I was 18 but that's many decades ago. :cool:
Sherman Bird
Houston, Texas
Likewise. I don't understand why they think they are so doggone smart by purchasing poor quality brake parts just because the price is so cheap. That 3 tom missile going 60 MPH takes every bit as much negative horsepower to stop it as it took positive HP to get there. This is done by absorbing and dissipating heat into the atmosphere. Sub standard brake parts as opposed to one's life, or someone else's? HMM.. a no brainer here.
EdGs
EdGs
FL
Actually my starting was never poor or problematic. No struggle or hesitation.
Just the low battery voltage message and the battery symbol in the evic.
I actually missed the corrosion because it was underneath the clamp, just barely visible
Now, when my first battery went, it was acting sluggish, just a little rrrrr at first crank, very subtle. I put it off for about a week. Went into a store one day, came out and "click". All she wrote.
RamDiver
2021 DS
OOPs, let me qualify that to be more accurate. :cool:
The first hint of a potentially compromised battery connection was that the battery voltage appeared reasonable when measured yet the EVIC had a CEL or battery fault light. Or could have presented with starting as poor or problematic.
Sometimes, when you've seen these faults so many times, they all seem to blend a bit. :)
HEMIMANN
Minneapolis, MN
6.4L HEMI
Not too long ago, Wal-Mart EverStart battery brand was rated highly by consumer trade orgs. It is / was made exclusively by Johnson Controls, Inc. Ever since they moved production from the midwest to Mexico, the quality went downhill - well documented (google it). More USA corporate race to the bottom.
EdGs
EdGs
FL
That sure seems right, I can remember EverStarts used to be really good.
Higher profit, quality suffers.
RamDiver
2021 DS
In this rapidly changing and bizarro world in which we live, the current state of affairs changes quite rapidly.
Unless the product has the Costco-like 5-year fully refundable feature, I'd want to make certain my research was very current before purchasing anything important like a starting battery.
YMMV :cool:
rosco11
1998 1500 4x4
What 2020 said. Battery. Dead or weak cell. Don't overthink it. 3 to 4 years is all you get from a battery. By design, imo.
pjs386
SW Florida
2014 RAM SLT
We get 4 years out of a battery in Florida. NO more than that, no matter what brand. They just fry in the heat and die unexpectedly - have had that happen twice to me. Now, when I reach the 4 year mark, I'll just buy a new Ever-max at Walmart for $149...Case closed!
DC Tradesman
Washington
Buy an interstate battery. Not a knock off from a auto parts chain. I believe batteries from the manufacturer are made cheaper. Mine only lasted 2 years. My truck is in a garage it still went bad. Interstate battery is about 5 pounds heavier than stock. It has to be thicker plates.
jdobbs876
Houston, TX
Average life of a battery in Florida is 2.5yrs. Cold temps will temporarily reduce battery power output, but heat breaks them down and destroys them. Florida sucks for battery life...always has.
I have lived in and around Houston, TX most of my life and the temperatures are just as hot and humid here. I just replaced my wife's original 2014 Durango battery 2 weeks ago. I replaced the battery in my 2017 Ram in June of 2018 and it is still going strong. The original battery was bad. Maybe it's the quality of the battery causing the short life.
