Battery Tender
DILLIGAF
Canadian Forces
Canada
I did not read through all of the posts, so someone may have mentioned it
AGM batteries need a AGM compatible charging unit
I don't know if it is the same for battery tenders
joeb
San Luis Obispo
Cummins 6.7L
I use the Deltran Battery Tender. Sometimes I drive very short trips in my truck, so even though the charging system works properly, I still float the AGMs. To make this easy, I rigged up a 7-way trailer connector to connect the battery tender. I used Anderson PowerPole connectors because they disconnect easily. That way, if I forget to unplug it, it unplugs itself without damage.
Reticle918
