Bed Anchors
KCJOE
KC
3.6L
Could someone direct me to a bed anchor that mounts to the inside of the beds sidewall (near the tailgate, but above the factory low mounts).
Thanks!
Burla
2010 Hemi Reg Cab 4x4
That would be nice, not sure how that would work, but was curious about that myself for maybe twenty years.
turkeybird56
Central Texas
Not seen ne thing like that in a RAM product. Saw on some foreign set ups, and also on military applications and such. All I have seen is the ones that go in the slots top of the bed as anchors. But alas, maybe there is some product out there.
ADDED: I sure as heck cannot imagine ne one drilling holes in the side of the bed as a anchor point. The beds sides are so thin ne way, not hold much, IMHO rip/pull out.
OK, Just saw this on a 2021 RAM Bighorn with MFT. Video shows side anchors with a rail. Unknown if it is specific to the MFT bed, but worth a preview ne way.
LouM
Marine Corps
Greeenwich/Easton upstate NY
2015 Ram Ecodiesel crewcab old/ 2019 Laramie Hemi old/ 2022 RAM 2500 6.7
eco diesel old / now Hemi missing the eco's mileage/ now back to enjoying diesel torqueesel
Those bed rails are the factory bed rails;
https://www.moparonlineparts.com/sku/82215286ab.html
They work good I have them on my 19,
i have looked a couple of times for extra tie down points for them but haven't found them,
so for now the factory 4 have to do.
KCJOE
KCJOE
KC
3.6L
Had an idea this morning.....remembered I have 2 leftover brackets from my running boards that might allow for mounting a D-ring at roughly the midpoint of the bed. If I get some time this week, I'll give it a try and post some pics.
Dean2
Near Edmonton
DEE ZEE DZ97913 Tie Down Kit RAM 2019+​
Brand: Dee Zee
4.2 out of 5 stars 25 ratings
| 4 answered questions
Price:
$37.07 + $9.18 shipping
Available at a lower price from other sellers that may not offer free Prime shipping.
MaterialAluminum
ColorBlack
BrandDEE ZEE
About this item​
  • Add tie down points into factory holes of RAM truck beds
  • Durable cast aluminum construction with a texture black powder coat finish
  • No drill installation into factory holes
  • Sold In Pairs
See more product details
Tim7139
Alberta, Canada
2020 Classic ST Crew 4x4
5.7 Hemi w/8 speed 3.92 gears
There is access from the bottom to put backing to spread the load in several places.
KCJOE
KCJOE
KC
3.6L
Exactly what I did here.....just a flat bar with a couple nuts welded to it. Definitely not intended to hold the heaviest loads, rather, tools or buckets that I'd like to keep snug against the tailgate.
RBJRBJ
Va
Hemi 5.7L V8 MDS VVT eTorque Engine
If you want to add additional cleats to your truck bed rails, search Amazon for PFCC PT278-35112 Bed Cleat for 2005-2015 Toyota Tacoma and Tundra (2) They fit perfectly on my 2021 RAM 1500 Longhorn Limited short bed.
Also available at Amazon are mini tie-down hooks that also fit perfectly in my 2021 RAM 1500 Longhorn Limited short bed: PFCC Replacement for Mini Tie-Down with Hooks Tacoma & Tundra PT278-35075 - 4PCS.
Despite being labeled for Toyota Tacoma and Tundra, they fit perfectly in the truck bed’s rails.
turkeybird56
Central Texas
WATCH yer vehicle emblems and make sure they do not warp and end up saying "PRIUS", (Joke). Heck of a find there.
Rado
US NAVY VETERAN
Navy Badge
Maine
Pentastar 3.6 V6
I have the Bed Rail as a tie down point as needed, BUT have added the EXTANG Cleats. You can change their location as needed !
And L Track , many brands out there
Jgaz
I saw this idea awhile back and have not completely given up on adding this to my Ram
2” Angle iron, 1/2“ round stock, this would be simple to weld up yourself or Id think pretty cheap to have made by a local welder
Jgaz
@LouM I have these rails as well. I was lucky enough to find three more tie down brackets in a pick n’ pull junkyard.
Before I found those I was experimenting using tee nuts that are used on a mill or drill press table. If you’d like a couple of pics, let me know I’ve still got these out in the shop
MantaRay67
Amazon has these Ram cleats listed that might fit the rails.
Not sure if they will work with my RamBoxes, but Amazon has an excellent return policy.
