Bed Drain Holes
mcharron
Diesel
I am going to install a Bakflip MX4 Tonneau cover on my '05 2500. I am not seeing the drain holes they are talking about me using. All I see are the slits at the front of the bed. I do have a LineX spray in liner that was put in when I bought the truck in '04. Does anyone know where these other holes are? Should I just drill out the slits and use them? I have looked, but not found anything specific to this. Thanks for any help.
MADDOG
Living in a Firepit
6.4L HEMI
Did you crawl underneath the truck and look up at the front corners of the bed?
M
mcharron
Diesel
All I saw was the little slits at the corners and the one in the middle
GTyankee
El Cajon Calif. 92021
3.0 ecodiesel
I had to open the slits up a bit after i had my bed Line-x
Then i sprayed the bare metal with a touch of paint, from the top & bottom
