Bed liner tie down hole covers
bendingwrenches
NY
V6
My truck came with a ram plastic bedliner installed. It's time to haul some bulk material, mulch, topsoil, etc. and I am concerned about the stuff getting under the bedliner thru the tiedown holes. If you google "bedliner tie down hole covers" it is a thing. Anyone know which ones might fit oem Ram bedliner tie down holes?
stimpy433
IOWA
I just always use an old trap to line the bed when I get mulch and stuff. Otherwise you might try some duct tape over the holes or another trick is to thread a old sock thru the tie down and the stuff it in the hole.
stimpy433
IOWA
I never knew they made them Thanks good to know, They are cheap enough for sure, Just measure the hole for the size you need should work !
BUT using the tarp would make clean up way easier IMO
Yes, cuz there is nothing worst then getting the crack between the bed and tailgate filled solid with mulch!!!!
Rado
US NAVY VETERAN
Navy Badge
Maine
Pentastar 3.6 V6
Picked my RAM up when it was a year old. Removed the bed liner to check out the bed and it had some dirt and straw in it, BUT dirt of mulch would travel far under there :O But agree with you on using a tarp at least !
Rado
US NAVY VETERAN
Navy Badge
Maine
Pentastar 3.6 V6
Quick check on eBay...they have Ford and GM .nothing for Ram.
Sent from my moto g(6) using Tapatalk
My guess is what is their size ? I believe RAM is 4" hole size. Not sure of the other makes
BWL
Embrace the skeptisism
BC Canada
I always thought stake pockets were a standard size.
Rado
US NAVY VETERAN
Navy Badge
Maine
Pentastar 3.6 V6
Not sure about stake pockets but I was talking about the hole in the plastic bed liner for the tie downs ! Now I have to find a Chevy and Ford to check the pockets lol
bendingwrenches
bendingwrenches
NY
V6
I pulled out one of covers that go around the tie down loops. Hole is exactly 4 inch. I ordered TrailFX PLUGKIT40X 4" Bed Liner Tie Down Hole Plug. The Ram liner looks very much like a TrailFX product.
I will l update the thread when I get them.
By the way, thanks for the helpful comments. I will be using a tarp between the bed and the tailgate!
