Craw
- Jun 22, 2017
- 589
- 254
- Location
- Western, Idaho
- 2013 Sport
- HEMI 5.7
So, was testing the 4x4 in the parking lot before I need it . Knew I could on the fly do 4x4 auto, high, lock but with low must go into neutral.
All 3 checked out but when I went to do 4x4 lock I pressed the nuetral button like normal. However this time the truck stayed in neutral wtf! Tried the column shifter would shift like normal but stayed in nuetral. Tried pressing the button. Tried doing the coulmn button for emergency no luck.
Called my Ram spot. Saved me.
So, what I went through to fix it.
1. E brake engaged
2. Hold neutral button down for 30 seconds or until truck prompts you to move the selector.
3. Move into drive then to park. Truck should prompt you to hold the brake down and move unto neutral where from there you can move into drive like normal.
Unsure, if there is a better method if so post it so I can edit my manual lol.
1. E brake engaged
