Belltech or Ground Force??
chipmaker
AZ
Belltech or GF, is there a ride or quality difference?? Looking at 2/4 kits...
EJM05
Somers, CT
440 Big Block
bump. hopefully someone chims in!
jojo750
south carolina
v6
both of those will be similar. both the BT and GF have springs and shocks.
take a look at mcgaughy kits too. made in the USA. they have one kit with just springs, and the deluxe kit has spindles for the front and springs for rear. no shocks are included in the MCG kits, but they do have the brackets for trac bar relocation, and longer dogbones for rear.
i have the deluxe kit installed, and bought the belltech street performance shocks for the rear. nice ride. maintains stock springs for the front, so suspension travel isnt changed.
post up what you decide. there are a few of us that have used each of the 4 kits available for the 4th gens.
quietpeen
2021 TRX
Hellcat
i know nothing about drops, bump for some more info beyond the great info that jojo posted
jojo750
south carolina
v6
whooops..
i made a small mistake.
i believe ground force only makes a 2/3 drop, not a 2/4.
so if you are looking specifically at a 2/4 drop, you have 3 main options.
belltech 963sp (springs, shocks)
mcgaughy 44052 (springs)
mcgaughy deluxe 44050 (spindles, springs)
you can always get a GF kit, and cut the rear springs to achieve the 2/4 if needed.
quietpeen
2021 TRX
Hellcat
jojo, thanks for the info update
JET
Arlington,Texas
1996/2011 Ram 1500 Sport
5.9 Magnum/Hemi 5.7
I have a 2/4 BT drop om my 1996.
Front Drop Spindles and Rear Leaf Springs and stage 2 shocks
I know yours is a 2012 but the 4 in drop in the back made ride like a tank.
Very little clearance between frame and axle.
Had to install a 2 in lift block and made for a better ride and no more banging the axle against the frame.
Maybe different now that they are springs and not leaf springs.
Hope this helps.
BigH0ss
Banned
Ground force here! Good kit.
chipmaker
chipmaker
AZ
Ordered Belltech kit, its not shipping for a couple weeks. I'll post before and after pics soon...
Krypt0n0tic
Houston, TX
I have the BT kit with street performance shocks on my 4th gen and it rides great, its awesome on the highway, and just a little stiffer ride on the street, just avoid potholes and go slow over speed bumps and u'll be fine. Hope ths helps.
blackout11
alpharetts GA
2011 R/T
I have a ground force and to be honest it rides better then stock
