Best brakes????
CG2742
Mesa
How are these with towing? The z36 is for a more towing application and I believe lists a bigger rotor and bigger pads than the z23. These r1 do they match factory size or are they bigger? I really want the dark coated ones
Nick@GotExhaust
Supporting Vendor
SC
The rotors will be the same size for any direct fit kit unless you are looking for a Big Brake Kit. The package we offer handles towing very well. If you tow heavy and often I may recommend going with a slotted only rotor. other wise for the occasional towing drilled and slotted will be fine as long as you have a true quality rotor like the R1 Geomets. Remember any color coated rotor will wear the colored coating off eventually where the pad meets the rotor.
let me know if you would like a quote or more info on anything. Just send me a PM
Also here is a link to our most popular and highly recommended brake package!
https://gotexhaust.com/i-23698983-2009-2018-ram-1500-got-exhaust-performance-brake-package.html
alphaprojects
