Bi Xenon HIDs don't work with foglights on?
05ram4x4
2002 Ram 2500 4x4 Quad cab
5.9 Magnum
I have a set of bi xenon hids in my 2002 ram 2500, non sport. If I have them on with the fog lights OFF, they work perfectly. Flash high and low, and high will stay on when I want it to.
If I have my fog lights ON, my low beams work fine, but if I turn my high beams on, or even flash them, they stay on. They shut off as soon as I push the knob in to turn off my fog lights. If I put a bulb in the passenger side headlight socket (the kit only plugs into the driver side), it works fine. Fog lights on or off.
Also, the fog lights are dimmer than usual when on with the hids.
So, here is what I've done. I tried the bulb in the socket as mentioned, and saw that it worked.
I tried a resistor kit, and it made no difference.
Any ideas?
dodge dude94
Millennial Boomer
East Texas
1998 Ram 1500
5.9 Magnum
Sounds like the relays that switch between high beam and fog aren't playing nice with your new HIDs.
I have no clue how to fix it as I don't deal with HID. lol
05ram4x4
05ram4x4
5.9 Magnum
I thought about wiring the fog lights to use a separate relay, but wasn't sure how the factory relay system worked.
dodge dude94
Millennial Boomer
East Texas
1998 Ram 1500
5.9 Magnum
Factory should have one relay.
Just for *****, remove the fog light relay and see what happens with the HIDs.
05ram4x4
05ram4x4
5.9 Magnum
Ill do that tomorrow. See what happens, and I shall report back.
05ram4x4
05ram4x4
5.9 Magnum
So, if I pull the fog light relay, the fog lights don't work, but the high and low beams work as they should.
dodge dude94
Millennial Boomer
East Texas
1998 Ram 1500
5.9 Magnum
That's what I was expecting. The fix from there tho....i have no idea.
05ram4x4
05ram4x4
5.9 Magnum
Ill try the jumper that people use so that the fog lights stay on with the highbeams. Do you know how to do that?
MagSport
South Carolina
Yeah there is a thread in the diy section for it, I can take some pictures of mine tomorrow also
05ram4x4
05ram4x4
5.9 Magnum
I searched for it and found it. Ill give it a try tomorrow.
05ram4x4
05ram4x4
5.9 Magnum
I did the jumper and everything works perfect now. I think I'll add a fuse and larger wire to it, but that seems to have fixed the issue.
dodge dude94
Millennial Boomer
East Texas
1998 Ram 1500
5.9 Magnum
Sweet!
But why do you need your crappy factory fogs with the HIDs? lol I don't even use mine except for dusk lights due to my LED headlights.
05ram4x4
05ram4x4
5.9 Magnum
Honestly, I just like the way they look with the color difference.
sbarron
Wasilla, Alaska
Dodge dude,Ive been curious..... How does a guy fro West Texas come to have a moose as an avatar?
dodge dude94
Millennial Boomer
East Texas
1998 Ram 1500
5.9 Magnum
*East Texas, thank you!:bleh:
Because I came across it a whole back and decided it was fitting due to the expression. Also, it's a tow mirror moose.
sbarron
Wasilla, Alaska
I get the tow mirrors just thought it odd for a swamp donkey to be known in texas lol
05ram4x4
05ram4x4
5.9 Magnum
It looks better in person at night and when my fogs are cleaner .
Sent from my SM-N910T using Tapatalk
phorrestphire
