Biggest tires on my truck
ClearwaterRam
New fish on the block here and was hoping to get some help. Got a 2014 1500 sport 4x2 and was hoping to put larger more aggressive tires on. I have zero knowledge about this stuff so please be easy.
From what I can gather I could get away with a 2 inch level kit and get some 295/60/20 in there , Rougly a 33 inch tire ) was hoping to do the most aggressive All Terrain looking tire out there (what ever that is)
I Keep it in the garage therefor cant go more than a level kit if I want to continue to keep it in there.
So my question for any of you guys that have had experience with my truck, what's the biggest thing you can fit.
I'm also doing some aftermarket rims if that matters.
3.5 inches is all the room I have to keep this thing in the garage.
thanks for the help. would love pictures if any of you guys got'em
Ram444
Cummins 6.7
44" Boggers should work great ( ;
brianw0048
EcoDiesel
do you mean wider or taller? My truck has factory 20s - 275/60/20 - it's a 33" tall tire. you won't need a lift/level for 33s.
WillO
South Florida
With super aggressive tires be aware they will be noisy and not last too long if your only on paved surfaces.
I went with BFG AT KO2, they are all terrain and look great and last a long time.
All down to personal preference though. These are what I have in 33
For comparison
C
ClearwaterRam
I guess wider, when I went a local shop he said I would have to do a level kit up front (2 inches) in order to fit a 33, I am assuming it was a 285/295 tire ( compared to my stock 275, therefore would need the level kit seeing as its wider and would rub inside somewhere.
And yeah I was thinking a AT tire, not mud , this thing will never see dirt and don't want the noise, just like to the look. Most guys around here seem to have TOYO's AT, just from what I see around driving.
C
ClearwaterRam
What would it take to fit 35's on there ? , could I get away with just a level kit lift on the front or got to go with a full 4 inch .
ameer73
