Bilstein 5100 leveling ?'s
jeffrey5679
Lake Stevens
Hemim 5.7
I ordered front 5100's to level out my 2020 big horn, will i need to also change out the rears with b8 5100's or will my stock ones work?
crazykid1994
If you are not lifting the rear you will be fine. The only reason to change is so they are matching.
BOWERSFJ
Uniontown OH
Exactly what he ^^^ said ...
Burla
2010 Hemi Reg Cab 4x4
2.8 takes out the rake, you will be level, oem back shocks will be fine. You may need zone control arms to protect the ball joints, at least that was needed in late 4 gens, but not early 4 gens. Burla have zero clue at 5 gens, but something to research. However, if you do use bills in the back, everything will be better. Firmer ride, better at keep load up, better at towing, going over trail or pot holes, etc.
