cacarter
On Monday I’m bringing my truck to Line-X and having a spray in bedliner done, along with a Magnum headache rack, and Bilstein 5100s installed, front and rear. I plan on having the front set at 2.1”, because I don’t want to have to replace the UCAs as well. I don’t do much off roading, and the dealer just put new General Grabber A/Ts on when I bought it, so I’m not going to replace the tires.
Question for others who have a similar setup:
At 2.1”, do you have rear spacers, or different coil springs? Are they necessary? Will there be a big gap in the front wheel well with stock tires and rims?
I don’t mind a little bit of rake, and I want to keep it close to the factory ride height. I plan on getting new wheels at some point, but I don’t want to lift it anymore than I mentioned. I also plan on many more mods, but I need to be careful, strategic, and slow, so I can keep the wife from filing for divorce.
Thanks!
Thanks!
