Bilsteins with 6" lift question
Djeazie
2013 Sport
I had a slight rake with my 5100 at 1.4. But from certain angles it just didn't look right to me. So I added 3/4" spacers to the rear springs. And yes that was an older rcx kit when they still have you springs with the kit. I personally didn't care for the rcx kit. And wouldn't buy another. I would do a BDS kit next time. Alittle more money but whatever. With the rcx kit I had a shimmy in the rear end on take off. Drove me nuts. They eventually made me a custom set of adjustable rear upper trailing arms. Which I actually never used because once o put the spacers in the shimmy went away. Must have changed the geometry just enough back there to fix it. Yet another reason I would stay away from rcx the second time. BDS kits just seem engineered better. But what do I know.
Djeazie
2013 Sport
And I personally wouldnt max out 5100's. You start getting into high cv angles. Which will cause you problems. Unless you buy high angle cv joints.
Thatdude596
buckeyes state
2009 ram big horn
best is bds, then zone or pro comp, then superlift, then **** country
my opinion
Thatdude596
buckeyes state
2009 ram big horn
no issues and running stock uca with 37s on 20s
Djeazie
2013 Sport
Hope that works out for you.
gassersarentdead
ohio
Someone lied to you
Djeazie
2013 Sport
You can develop a cv wobble with them at a such a high angle. I've seen on friends trucks. I've had numerous lifted trucks and sometimes it happens. If you do them with a lift kit the kits spindles help to keep that angle in check. Nothing guaranteed though. But whatever.
jstacey8
hiram maine
Rcx kit come with a preload spacer so the most you could do is set bills at 0.7 and the preload spacer
Drummin4jc
Drummin4jc
WWG1WGA!
SW Pennsylvania
2024 Ram 2500 CC
Well, I think I've finally decided on what I'm going to go with for this project. Let me know what you guys think:
Zone D21N 6" suspension lift kit with 5" coils
Fuel Vapor D560 wheels 20x10 with -18 offset
Toyo Tires Open Country M/T 35x12.50x20 tires
Bilstein 5100 front shocks
I Was also thinking of getting like, 1" rear coil spacers for the rear so when I do load her up a little, my nose won't be real high in the air. I don't mind having the rear up a little higher than the front but I wanted t get the maximum lift I can out of the kit/bils. Let me know what you guys think!
Adam
smoothee
St. John's, NL
Yeah, ditch the preload spacers if you're gonna be running Bilstein's.
That'll be a good setup. The only thing I'm thinking is the 35's might look a bit small though, especially if you decide to add rear spacers and set the Bilstein's above 1.4".
Drummin4jc
Drummin4jc
WWG1WGA!
SW Pennsylvania
2024 Ram 2500 CC
Why ditch the pre-loaded spacers?
Adam
Djeazie
2013 Sport
To keep your rake in check when loaded, look into a set of airbags.
KAKA
