Bird chirp sound
lw13ram
3.6l
I installed the Bilstein 5100 set at 2.1 on my 2015 about 6 months ago. About 3 months ago I noticed a chirping sound every once and a while while drive through my yard. Now it's almost every time I go over just slight bumps. Are there any bushing or links that could be going bad that I need to change?
Tim Garceau
Banned
Eagle River
2014 Sport Quad BSP
3.92 8 Speed 5.7 4X4
The common issue is wrong installation where the washer is placed over the strut hat instead of underneath. The shock shaft pushes through the hat and will let you know.
A squeak can be any rubber bushing however.
ram1500rsm
Trabuco Canyon, CA
It could be one of the shocks is defective, or it could be famous 5100 washer that wasn't installed properly, it could be any bushing in the front or rear, it could be your sway links front or rear, could be your mopar skids assuming you have those. It'll be good if you could try to narrow down where the noise is coming from and you may need a helper for that.
wbsnow93
I 2nd what Tim said. I had the chirp issue and just kept hitting it with wd40 and motorcycle chain grease, I was sure I installed them correctly. Until 6 months later one shock popped through and I realized I put the washer on the wrong side.
Sent from my SM-G988U1 using Tapatalk
misfit77
My coworker had the issue. I think it ending up being the fact that they tightened the bushings while the truck was on the lift.
Sent from my moto g power using Tapatalk
lw13ram
lw13ram
3.6l
Thanks for all the replies! I'll be doing to wd40 way this weekend
kurek
Northwest
Wait is this going to be that washer thing again?
KwyjiboJonesJr
