Bender02
Well blew up my 14 ed last night. Looks like the oil pan gasket went and I didn’t get it shut down in time. Anyone ever had this happen? Will talk to the dealership tomorrow but good news is it’s still under warranty.
Yea I’ve seen a lot of guys having issues with blowing the motors due to a failing egr cooler. Just couldn’t find anyone talking about an oil pan gasket blowing out. Wondering if I had a ring failure or blew a hole in a piston? Seems like too much pressure in the bottom end if you blow that pan gasket.Yes several hundred people on this forum have had the same problem!! ............... Ram1500Diesel.com is the largest RAM 1500 Diesel forum community on the web with discussions on 2014+ Ram EcoDiesel trucks.
Your saying the oil pan gasket blew out? That would definitely be a first I've heard of. Are you sure the pan and lower part of the block is still intact? I've heard of parts of the lower rotating assembly deciding it no longer wants to be within the engine and escaping but not just a pan gasket letting goSeems like too much pressure in the bottom end if you blow that pan gasket.
I’m only guessing at the gasket. Both sides of the lower motor portion are all wet with oil. Egr cooler and top sides of motor are still clean. There was a couple seconds of harsh grinding and metal on metal noise then it abruptly shut down. Flashed low oil pressure real quick before the grinding noise but no check engine lights or anything is on the dash or in the stored messages.Your saying the oil pan gasket blew out? That would definitely be a first I've heard of. Are you sure the pan and lower part of the block is still intact? I've heard of parts of the lower rotating assembly deciding it no longer wants to be within the engine and escaping but not just a pan gasket letting go
100738How many miles does your truck have?
