blind spot mirrors
Jeff CA
NorCal
I picked up a set of new Wadestar blind spot mirrors. I really enjoy the new design. They make it much safer to drive and I don't have to try to look out the left rear window when merging left anymore. They're 20 bucks well spent. Suggestion: mount them in the lower corner of your mirror. The upper corner shows too much sky and too little vehicles.
fire101fighter
South Jersey
Totally agree! The new design is awesome and well worth the $20! They're a must have for the non-towing mirrors
EagleChief
Oklahoma
2014 Big Horn
I stuck mine in the lower corners also. I think they are better there... more field of view of the road. I had my previous "other brand" of blind spots on the upper corners, and they were ok, but too little. I love Wade's version!
Rzrman328
The treeline
May have to invest in a set. Almost ran over a smart car yesterday.
TerraNewf
NL, Canada
I've received mine as well but haven't had a chance to install yet. Lower outside corner will be the spot
avantiguy
Bay City, Mi
hemi
Try them in both spots, just a little masking tape will hold them. I found that the upper outer corner was much better for me.
I'd guess it depends on ones height, seating position and other variables.
Bfazona
Harmans, MD
I like the lower corner as well. I used to drive a Ford with the blind spot mirrors on the bottom, so I'm used to that being the spot.
SitKneelBend
Moderator
Member Relations Specialist
St. Louis
3.6 Pentastar
I split the difference, driver on top, passenger on bottom.
TerraNewf
NL, Canada
You make a very good point, I'll do the masking tape thing and see what works best. Thanks for the idea
Divinggumby
SE PA / NJ
How are these holding up?
$8 for the set looks worth the gamble.
I've only had them for two weeks or at least one for two weeks. I didn't have the drivers on too well, the wife shut the door when she took it the one night and it fell off. Someone ran it over, there was glass in the street so I was surprised to see it glass and not the shiny plastic. When you stick them on they're on there good since I checked the passengers side after the drivers fell off and it was on there solid.
Ray2004
Not a closeup but you can see it. $6 at Autozone and they are great. Unlike some mirrors, you can see the back tire which helps with the centering between lines in parking spots.
blackbetty14
CT
Hemi 5.7 VVT/Etorque
Does anyone have the link the wadestars for $20?
02Steve15
Connecticut
Those were the first things I bought for my previous truck and my current. They are great. Around $10 at walmart.
Jeff CA
Jeff CA
NorCal
My generation 2 mirrors started to peel (an early manufacturing defect that is now corrected) and Wade sent me a new ones for free. Continued stellar customer service from Wadestar!!! I recommend these mirrors, as they work great and allow you to see our truck's massive blind spots. I feel much safer now.
DavidN
Central Florida
Yes, a great product!
adubree86
Indianapolis, IN
2017 Ram 2500
I went top corner since I was used to my 08 ram tow mirrors. They are great.
mrhankie
