Truckgang
5.3 Hemi
My left side headlight was stripped out, all that was left was the pigtail that goes to the high beam (I have dual and not quad headlights, it’s a 2012) and the wires for the lowbeam. So I purchased the pigtail for the lowbeam, and the socket that goes into the bulb. I crimped the new wires back onto the old wires, and currency tested it. It says a current is running through each wire, and the bulb lights up. However the blinker won’t blink. If anyone knows why this may be any help is much appreciated, and if I wasn’t clear enough I’d be happy to specify anythying
1500ram12
5.9L Cummins
The wiring is the same whether you have dual or quads from 09-18. Only difference is on the quad headlights the wiring splits inside the housing so it has separate low and high beam bulbs. I believe on the 09-12 the connector for the low/high beams is green and the turn/park connector is black or dark Grey. Verify that you have everything wired correctly
2018 Ram 2500 6.4L Hemi Tradesman
