Blown
D Reed
Ma
Hey everyone, I have a 2011 1500 with the 5.7. I put a cam kit in it from MMXtreme and deleted the MDS. It's been in for about 13k miles and now I have a lifter tick. What companies have people used for a remanufactured engine? I am looking at Hemi Pros.
SCredleg
SC
When you installed the cam kit, when you removed the exhaust manifolds during the tear down, were any of the bolts broken? Did you reinstall your original exhaust manifolds? If so, were they warped and did you resurface them before reinstalling?
D
D Reed
Ma
I fixed 3 broken bolts on the heads and replaced the rh manifold. New engine is being ordered tomorrow from Dodge
jws123
nj
A hemi will always have a small lifter tic how bad is it? Post a vid bet it sounds better then mine i had lifters and a cam 10k ago as long as you have no missfire run the **** outa it. Also make sure to use a good oil ad royal pup filter helps alot.
No members online now.
Raadz
