Blue tooth issues
15 Handicap
Central Florida
Blue Streak Pearl Coat 3.6
Anyone have an intermittent issue of it not connecting/recognizing your contacts? Even when this happens if you try to "dial" with the number it screws up the number you give to it? I have repaired it and it still does it 4 out of 7 days week. Radio needs to be refreshed? This truck was new in November last year.
wallacemf
2500 4x4 Hemi 6.4
Don’t know if you have an iPhone, but I’ve had odd issues like this after updating the iOS version. Usually I have to clear the phone and address book data out of the system and pair it again to download the address book all over again.....
15 Handicap
15 Handicap
Central Florida
It's a Samsung S8. repaired and it still periodically does it
stimpy433
IOWA
Did you make sure you deleted the pairing on the phone and the radio both????
Riccochet
Somewhere around Charlotte
2020 2500 Laramie Longhorn
Try changing the Bluetooth AVRCP version. To do this you'll need to activate developer options on your phone. Go to Settings -> About Phone -> Software Info and tap on the build number 7 times. You'll get a pop up saying dev options is enabled. Now back out to the main settings window and you'll see Developer Options there. Go in, find Bluetooth AVRCP Version and change it to 1.3. This corrected a lot of bluetooth issues for me.
Worth a shot.
