Body Cab Mounts
Bennutts
Cummins 6.7
Has anyone replaced the a-pillar body cab mounts? I've got a ton of squeak and clunk and that's what I have narrowed it down to after doing some research. I did search for threads on this website but didn't come across anything for 4th gen Rams.
crazy jerry
WY
i could be wrong but it looked like the whole cab needs to be lifted up to replace the body mounts
DodgeDude99
Oak Lawn, Illinois
treat it like a body lift. Loosen the bolts on one side, remove the bolts on the other and jack that side up to do the work, let down, leave the loose and do the same process on the other side.
Bennutts
Bennutts
Cummins 6.7
This is the process I’m gonna try. The truck has over 140k on it but I’m still within the 3/36 from the dealership. I also have an extended warranty. Think that there is any chance I can get the dealership which is not a Ram dealer, to fix this under warranty since there is a TSB for it?
