Body lift issues
Kristy Midkiff
WV
I just had a body lift installed on my 2016 Ram and now my headlights and front signals don’t work and I get the code flashing on my dash about it. The fog lights work and the park lights, but not the headlights and signals. Please help with any ideas. Thanks
MADDOG
Living in a Firepit
The simplest answer would be they didn't get the harness plugged in properly.
K
Kristy Midkiff
WV
I just double checked the headlights and my headlights are blinking like the signal lights should be when I turn my signals on. Does that mean that something is just plugged in backwards?
averageguy
Belleville Mi
hemi
Usually the factory plugs can only plug in one way and into the corresponding plug. Maybe they left a ground unhooked? The best thing to do if your not finding anything simple is to take it back and let the installer of the lift figure it out. At least call and explain the issue and maybe they will know what is causing it.
K
Kristy Midkiff
WV
Unfortunately they haven’t been able to find anything that would cause it. They said they added a couple extra grounds trying to fix it and still didn’t work
JB1
Houston, Texas
Maybe they smashed over some pins on the male side of the connectors
olyelr
Kewadin MI
Not really any help here, but why would you even unplug the lights for a bodylift?
shadowhawk
Southeast WI
hemi 5.7 with I2 tune
if it's the zone 1.5" version, you have to relocate the bumper after drilling new holes
Tim Garceau
Banned
Eagle River
2014 Sport Quad BSP
3.92 8 Speed 5.7 4X4
They probably pinched a harness and are pleading ignorance because your name is Kristy. Have them fix it at their cost.
olyelr
Kewadin MI
Well yea, I would guess any brand body lift has to raise the bumper. So maybe unhook fog light harness if you completely remove it, but cant imagine you would have to do anything with the headlights.
