Body lift question
brasso
2012 ram 1500 4x4
Is it possible to have a body lift which lifts the front 3" but the back only 2"? I like the front to be a tad bit more lifted than the back. Not by a whole whole lot but because the way the rams are built it almost doesn't look level even with my bilsteins set at 2.8… I plan on putting a Body lift along with my bilsteins set at 2.8
SETEX 6.4
Port Neches, TX
It could be done but it would look like crap.
The body lines would no longer line up.
That would look worse than the rake your are referring to IMO.
xrsman
Ontario
3.0 Ecodiesel
I don't think there is a body lift made for 4th gen rams that is a 2". You might be able to have one custom made but that would probably be expensive. Maybe you could cut the rear coils down a bit to to get the look you're after? Here's mine - it has a 3" PA Body Lift, 2" front level with a 1.5" rear spacer level. It has a slight rake to it (rear is higher) but it's hard to tell!
Wandell
Cummins 6.7
Short answer, no.
