Bogs down when trying to excellerate
Tracyblue55
Louisville KY
I have just purchased a 2003 Dodge ram 1500 4.7 two-wheel drive I have done new plugs new coil cleaned throttle body changed a few sensors calipers having trouble when I try to take off from the stop it's like something is holding it back from going. I have since replaced the PCM and had it programmed catalytic converters were cut off of it when I first bought so I had pipe put in from the front to the muffler still can't understand why it feels like it's chained down trying to go forward and drive but in reverse no problem idles great forward won't idle forward stays running but won't idle forward.two-wheel drive please help
T
Tracyblue55
Louisville KY
Also the indicator light on the park reverse neutral drive 12 is where it blocks it out say about gear in it disappears after all lights go out brake light is flashing also throws code p1698 and p1604 what do I need to do and now throwing code p1603
Daw14
South Florida
Are your brakes sticking ? Spin each wheel and be sure it’s not the brakes .
T
Tracyblue55
Louisville KY
None of them spin freely and I just replaced hub barring a and calipers it's weird
10 Break
Dayton, OH
Did you replace the brake hoses? The inner lining can collapse and act as a check valve, preventing the piston from letting go.
