Boost levels change
schroederMP
Indiana
Cummins
Help me out...
When I'm driving on the interstate (truck is already warm and at operating temps) my boost will be setting at around 10 psi (flat ground) and my egts will be hovering around the 700* mark...well about 30-45 minutes into the trip, my boost will drop to about 6 psi and my egts right around the 600* mark?
Why is this happening? Were I drove to has an elevation change of only 100 ft or so. Would that cause it?
ramhunter9
P-Star Jeep Wrangler
That sounds about right to me .. Higher boost higher EGT
schroederMP
schroederMP
Indiana
Cummins
Yea thats normal... but why would I randomly have a lower boost on the same stretch of highway (flat highway) at the same speed?
ramhunter9
No idea
Mopar1973Man
New Meadows, Idaho
1996 Dodge 1500 (V8-5.9L) & 2002 Dodge Ram 2500 (5.9L Cummins)
I typically see about 2-3 PSI boost at about 500-550*F at 55 MPH.
But my boost pressure will wonder up and down depending of load and grade...
schroederMP
schroederMP
Indiana
Cummins
Thanks... its just weird that they will be 1 level at one poit, then another level at another point under the same cercumstance (mph, grade)
I dunno... I was just wondering
Uncle Ugly
Remember that boost pressures and EGT's are also related to air density and weather changes.
Simple changes to humidity can and will make changes like this also.
Stangshcky12
Oshkosh, WI
5.9 Cummins
Hm never really put that together lol
Pgage=Psystem-Patmosphere
Mopar1973Man
New Meadows, Idaho
Or just get a PSIa Gauge... (Pound per Square Inch Atomsphere)... So 14.7 PSI is normal atomsphere and 0 PSIa would be 30" inches of vacuum...
Just another way to look at it...
Mopar1973Man
New Meadows, Idaho
Just hit me... Tail wind... Less load on the engine and less fuel being consumed...
Jantelaw
