kris319
I purchased a set of two Bora 1.5" spacers from Motorsport-Tech but after installing my wheels and tires I decided to go with a larger spacer. One of the spacers may have some light marks on it because I installed it to test fit but never actually bolted down the tire or drove with it on. The other spacer was delivered with a small chip but it shouldn't be an issue, it can be seen in a picture below.
Keep in mind that depending on how the back of your wheels are cut out, you may have to trim your studs a bit.
These are 5x5.5 139.7mm and fit 2012-2015 Ram 1500 and Dakotas
I'm asking $100 shipped. You save $30 and 3+ weeks of wait!
