botched paint job
DDean
So I have a pretty botched paint job on my front bumper. I care not to share details lol.. what's the best way to remove paint?
steermaster
CO
5.7L
Freshly wet you can use paint thinner, but good way is to sand it off and prep it again for your new job
DDean
DDean
It isn't fresh it's been on there since last summer but it didn't survive the alaska winter and it all cracked up and chipping off now, looks pretty bad. Good news is I just wash and waxed the rest of it and so it looks nice everywhere else haha
NorthTexasHemi
DFW Texas
2014 RAM 1500 Lone Star
Probably use pressure washer to get rid of the loose paint then sand and prep and repaint.
hotkarl
4.7 Semi-Hemi
If it needs to be totally stripped down use aircraft remover or an equivalent paint stripper, it'll speed up the process (I know I hate sanding, hand, machine or otherwise). Once you let the stripper do the bull work, just sand the crap out of it and proceed with the refinish process from square one. I've become a big fan of paint stripper.
05daytona
Hit it with a pressure washer, then use a stripper that's safe for plastic. Once it's down to bare plastic and right before and I mean right before you paint it, you need to use an adhesion promoter. That's most likely the reason it peeled to begin with.
DDean
DDean
Thanks for the advice guys
DDean
DDean
Just for grins and anyone else wondering about paint removal it can be done. Stripped it back down to the chrome.
DDean
DDean
Plenty of people have done it. In other news I finished swapping all my dash lights out with LED bulbs today. So there's a win.
05daytona
That doesn't mean it was done right. In order to do it right, all of the chrome needs to be sandblasted off and the proper prep done if you expect it to last any length of time.
DDean
DDean
Agreed which is why I have all the correct stuff this time around. Lesson has been learned.
Sitedrifter
I know you can do it but did you sand down the chrome and use etching primer? You really need to use something like 60 or 80 grit paper and then when it is totally sanded to a very rough finish, work your way up with finer sand paper to maybe 220 grit. The etching primer is a main key to doing this and it hold up.
