bouncy ridr after front coil spacer installed
SwollenMonkey16
Anyone else feel like their ride is more bouncy after installing a 2.5" front coil spacer? I didn't install the shock extender bc it was too long do you think this could be the issue?
MADDOG
Living in a Firepit
6.4L HEMI
Yup...mine got a bit bouncier.
I used a kit that had a shock relocation bracket and I'm sure it helped. Of course, mine is a 2500 so YMMV.
SwollenMonkey16
SwollenMonkey16
Just got an alignment and it feels a little better not sure if it's just my head. I tried putting on the shock extensions but seemed too long maybe I need to try it again.
PassivAggressor
New shocks. Get some Bilsteins or some other brand with better valving. Mine was bouncy as hell with stock shocks.
Reo Cook
Houston
5.7L HEMI
Spacers preload the spring so it does make the ride stiffer. I had my 11 with 2.5" spacers and on my 14 I went with new springs.
SwollenMonkey16
SwollenMonkey16
I'm definitely thinking about upgrading shocks. Did you replace the stock springs with lift springs instead of the spacer set up?
