Brake controller/SGW module
Alexgo
Puyallup
Ecodiesel V6
Hi, I have 2018 Ram ecodiesel and I installed a Oem molar brake controller. Followed the install procedure everything was done correctly. But after going into Alfaobd to program I found out the Security Gateway Module won’t allow me to program it in. Where is the module located? And can it be unplugged temporarily yo program or do I need a bypass cable?
SitKneelBend
Moderator
Member Relations Specialist
St. Louis
3.6 Pentastar
You must have a bypass cable. M2Mods is a forum vendor and member(s) who can get you the cable you need. @Mpgrimm2
Bigskyroadglide
Moderator
Moderator Supporting Member
Montana, officially RETIRED
Hemi 5.7, supercharged
Remember with alfa, you have to "enable or turn on" 4 separate functions for it to work properly
joshhhh
