Brake fluid full replacement (bleed)
Bruno rubio
Houston
Hi all, how many quarts of brake fluid should I buy to fully replace the fluid currently in my truck?
ram 1500 2014 5.7
thanks in advance
Bruno
gixxer
SK Canada
4.7L
1 quart will be more than enough if my memory serves me correctly, but you can always get an extra and return if you don't use it. Depends if you introduce air into the system accidentally.
I use a vacuum machine so its quick and easy with very little waste.
Rgesse
