Brake issue
2014greatwhite
Western mass
I installed powerstop extreme truck and tow drilled and slotted pads and rotors. I have 1500-2000 miles on them. On initial braking of the ride they will squeal. Then that’s it unless truck sits for 5-6 hours then again initial braking of that ride the squeal is back. They sent me new pads under warranty. Good for a week then right back to same thing. They suggested I clean my rotors with soapy water. Does it sound like I might have a sticky caliper? It almost seems like one of he rotors has a film or glazing or something developing on it when it sits for a little bit. Any thoughts?
huntergreen
Marine Corps Navy Badge
Clean as recommended and see what happens..
Nick@GotExhaust
Supporting Vendor
SC
did you do a proper bedding procedure with the new pads and rotors? If they didnt get bedded correctly that could cause issues. Also did you clean everything prior to install and grease guide pins? I also like to lightly grease the back of the pads as they can squeal when/if they vibrate in the caliper under braking
c duncan
