Brake light out warning after LED headlight install
Shawn Burns
Army Law Enforcement
Lewisburg, PA
2016 Rebel
I recently installed low and high beam LED's from LASFit. The install went fine, but I occasionally get a brake lamp out warning in the dash. I purchased alfaobd and I made sure that all of the lights are LED. I still got the warning. The headlights work great with no flickering and I am otherwise very happy with them. What else could be the problem?
I followed the steps for alfaobd in this youtube video...
if your brake lights are fine, check the third brake light on the cab. When it goes out it will register as a brake light out.
S
Shawn Burns
Lewisburg, PA
2016 Rebel
I will check that one. It was replaced with an LED when I bought the truck. I'd be dissapointed if that was out already.
joelmic
stl mo
2022 Ram 1500 Big Horn 4dr Quad Cab 4WD SB
Mine go out once every 2 years maybe... it's pretty common for me at least
indept
South Jersey
I replaced my bulbs with LED & set them using Alphaobd to set them to LED. I did that in 2017 and once each spring & fall I get the bulb out warning. It clears after driving for 20 -30 minutes and doesn't do it again until the next spring / fall. I'm used to it now.
S
Shawn Burns
Lewisburg, PA
2016 Rebel
I checked the third light... initially it wasn't lit. I pulled the bulb and reversed it. It then was partially lit. That explains the intermittent dash warning. I bought a replacement that I will install as soon as I have the time. It seems the bulb was on its way out.
S
Shawn Burns
Lewisburg, PA
2016 Rebel
Now I feel stupid for not checking what the warning message actually warned of! I thought for sure it was some conflict with the LED headlights that I just installed. What are the chances that a brake light bulb went out at the same time that installed new headlights?
LeeD
Humble, TX United States
I don’t know the odds of that happening but if I were to do the same job I’d put my odds of it happening at 90%.
Justin33
Murphy’s Law
Rado
US NAVY VETERAN
Navy Badge
Maine
Pentastar 3.6 V6
I had the light out flash as well once in awhile. Found out it was the bulb like youe did. Bulb looked good but and worked but something was broke in it lol
turkeybird56
Central Texas
Wat U do, take out one of your Dingy's running light bulbs and put it into the RAM??? LOL... :angels25:
Just a BOIRD, lol.
Rado
US NAVY VETERAN
Navy Badge
Maine
Pentastar 3.6 V6
Kmiko
