kami
1999 with a 5.9. I have vacuum on Brake booster, fluid is coming out of master cylinder when i loosing the nuts going out to proportional valve,NO FLUID COMING OUT OF HCU when i loosened the line going out to the rear brakes.I did take the ABS Module out and clean the wires and put that back and brake pedal got some kind of better than before but still front calipers are locked and pedal goes down after a little while. Iam at the point after watching youtube to get a new Master cylinder and hope that put everything back to normal.thank you and Appreciate your Help
